Stainless Steel Pipe Tube
johnny123
Mensaje por johnny123 » Mar Dic 03, 2019 9:45 pm
201 Stainless Steel Pipe Tube
201Stainless Steel Pipe Tube is a lower cost alternative to conventional Cr-Ni stainless steels, If you are looking for prime stainless steel material,Asia Steel & Iron Co.,Ltd is the best choice for you. We are the professional manufacturer,exporter, stockiest of stainless steel and specialty stainless steel pipe tube , fittings ,flange ,for more than 20 years. With the strength of good quality, competitive price, a large number of stock, good after-sale service, we have been cooperating with many famous companies, such as the PDVSA, KOC , TOTAL.
Specification
Grade201 stainless steel pipe tube
StandardASTM A269, ASTM A554. ASTM A632, ASTM A1016/A1016M
Diameter10-60.3 mm
Thickness0.2-10.0mm
Length2000 mm-12000mm or as customers' request
Surface NO1,No.4, 2B, BA, 6K, 8K, Hair Line with PVC
Chemical Composition
GradeCSiMnP≤S≤CrMoNiOther
201
(mid copper)≤0.15≤1.0010-110.0450.0312-14-0.8-1.0Cu 0.8-1.0
201
(high copper)≤0.15≤1.009.5-100.040.0313-15-1.0-1.2Cu 1.4-1.6
Mechanical properties
GradeYS(Mpa) ≥TS (Mpa) ≥El (%)≥Hardness(HV) ≤
201
(mid copper)20052025210
201
(high copper)20052035210
Product Show
Application
200 series of stainless steel are used widely, Typical applications for 200 series are cookware, hose clamps, piston rings, transit car structural member,
Transit car roofing/siding, thermal window spacers, air bag containers, and truck trailer posts and door frame.
website:http://www.asian-steel.com/stainless-steel-pipe-tube/
